[gdal-dev] ReadRaster hangup in gdal2tiles
Per Ohlson
per.ohlson at nanight.se
Sun Jan 6 07:46:34 PST 2013
I'm having a bit of an issue with tiling some of my GTIFFs using the gdal2tiles-script.
Here is verbose print of the last lines:
(64, '/', 256, '/MapTiling/temp/A00022_RGBA/6/63/27.png')
('\tNative Extent (querysize', 451, '): ', (28415, 0, 451, 128), (0, 323, 451, 128))
('\tReadRaster Extent: ', (28415, 0, 451, 128), (0, 733, 1024, 291))
And here it just sits.. though still using 100% CPU on one of the cores.
I'm have been trying this with gdal 1.9, 1.92 and now built the latest code directly from the HEAD branch.
Any suggestions about what to do?
I'm using the following line to run gdal_translate:
gdal_translate -of GTiff -b 1 -b 2 -b 3 -b 4 /MapTiling/temp/A00022_RGBA.tif /MapTiling/temp/A00022_RGBA.gtiff
Regards
/Per
Per Ohlson, M.Sc. E.E.
Nanight AB - http://www.nanight.se
Stockholm/Gothenburg, Sweden
per.ohlson at nanight-tech.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130106/95490c00/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130106/95490c00/attachment.png>
