[gdal-dev] Creating Raster using Spatial Coordinates (Latitude and Longitude)
Dheeraj Reddy Mamidi drmamidi at rothwellgroup.com
Wed Jan 16 16:25:08 PST 2013
I am trying to create a Raster using grid of points(with latitude and
longitude values) within an area which are separated at a distance measured
in degrees. At higher latitudes the number of samples reduce that is number
of points for a row reduces.
When distance between points is determined with a fixed degree, how do I
create a raster where the number of columns for higher latitudes reduces ?
In this case, points for grid at higher latitudes are not exactly above the
points at lower latitudes. Can some one suggest a way to create raster for
spatial coordinates in this case?
Thanks,
Dheeraj
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130116/540d6f48/attachment.html>
