[gdal-dev] Creating Raster using Spatial Coordinates (Latitude and Longitude)
Dheeraj Reddy Mamidi
drmamidi at rothwellgroup.com
Wed Jan 16 16:26:59 PST 2013
I am using C# Gdal library.
On Wed, Jan 16, 2013 at 5:25 PM, Dheeraj Reddy Mamidi <
drmamidi at rothwellgroup.com> wrote:
> Hi,
> I am trying to create a Raster using grid of points(with latitude and
> longitude values) within an area which are separated at a distance measured
> in degrees. At higher latitudes the number of samples reduce that is number
> of points for a row reduces.
> When distance between points is determined with a fixed degree, how do I
> create a raster where the number of columns for higher latitudes reduces ?
> In this case, points for grid at higher latitudes are not exactly above the
> points at lower latitudes. Can some one suggest a way to create raster for
> spatial coordinates in this case?
> Thanks,
> Dheeraj
Software Developer
The Rothwell Group, L.P.
Email: drmamidi at rothwellgroup.com <atvaughan at rothwellgroup.com>
Phone: 713-952-5355 ext.30
Web: www.rothwellgroup.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130116/79677178/attachment.html>
