[gdal-dev] GDAL correlator [thoughts]
Dmitriy Baryshnikov
bishop.dev at gmail.com
Tue Jan 22 22:56:39 PST 2013
Hi Cristian,
I don't understand what really you want to do. There is a normal way to
improve GDAL - make changes in local SVN snapshot and provide patches.
If you need any help feel free to ask.
Best regards,
Dmitriy
22.01.2013 15:46, Cristian Balint пишет:
> Dear All,
> - In recent days I saw this thread:
> http://lists.osgeo.org/pipermail/gdal-dev/2012-August/033897.html
> subject to a feature that would be requested in GDAL. Also I am
> looking at initial requirements here:
> http://trac.osgeo.org/gdal/wiki/Correlator
> * I walk through the thread, and found some issues and concerns. You
> may find interesting some of my comments and observations:
> a) Looking thorough the code proposed seems like only co-registration
> of only two image is possible at once (?), and implementation uses
> SURF keypoint detector.
> - SURF and also SIFT descriptors are patented algorithms, even
> OpenCV decided to move out such code in a "non-free" called
> sub-folder, see here:
> http://code.opencv.org/projects/opencv/repository/revisions/master/show/modules/nonfree/src
> - Their, and also any other SIFT or SURF implementation of the
> original papers are considered "non-free", however there are much
> better options than those two.
> b) There are free alternatives such BRISK, FREAK, ORB (in order of
> their quality), that operates even in hamming space instead of euclid
> (provides very fast and dense match),
> also have the ability to tell the exact amount of features extracted
> (SIFT does not have e.g), so extraction can be surrpressed to X best
> quality amount of.
> c) I can't see where is FLANN matcher in the code, FLANN can provide
> huge speed-up booth for euclid and hamming space descriptors, also
> doing little post-filtering and validation with a small homography
> calculs using RANSAC would take a big boost for further
> gradient-descent steps, and it would take additional <1 millisecond
> plus to find and eliminate outliers as a post-process after keypoint
> matching. Also can decide if a pair is matchable or not matchable at
> all. This way also gradient-descent will be not overloaded with too
> many bad outliers.
> d) Regarding multi-band rasters, a good approach in case of RGB
> rasters is to sum channels: (0.299*R+0.587*G+0.114*B)/3 - 0.5 (thats
> exactly how e.g opencv is doing, and how some of CVision community are
> doing, not sure how this recepie camed up), but very same results in
> my very experience is also with plain (R+G+B)/3 , suitable with any N
> band rasters, in worse case of too many raster-bands user could select
> what raster bands to take in consideration at matching steps.
> e) I don't got the point with "segmentation". Perhaps the idea was
> born since doing SURF or SIFT detection over hi-res >50k*50k rasters
> is painfully slow, but is not the case at all with BRISK or other such
> descriptors. The approach to chop down rasters is not bad anyway, but
> take in account that will significantly increase required matching
> amount across pairs, since the rasters will increase in count.
> * Performance boosts can be achieved, also n-to-n rasters can be addressed:
> 1) To address co-registration of massive collection of datasets (not
> only single pairs at once) without any prior knowledge of any
> relationships will need to brute-force and test all images against all
> neighbouring images, that require a minimum (n)*(n-1)/2 computation
> expense, counting that for each pair-match best speed could be ~10ms
> per pair (E.G using BRISK in best configuration with FLANN).
> 2) If prior knowledge exists (e.g. rasters have a declared coordinate
> frame), then is more easy, only overlapping rasters must be checked
> and registered, perhaps in much dense and deep way with more amount of
> extracted features per image.
> 3) Regarding smooth fusion of pixels and gradient descent error
> minimization OpenCV really holds very nice routines doing that (using
> state of art Levenberg-Marquard minimization), also have options to
> select some projection-mode. Using some additional serialization
> tricks (using smaller block of rasters at once in memory, GDAL
> routines can address this with ease) by avoiding memory greedy OpenCV
> internal raster routines, it can go up with massive amount of pixels
> (infinite) for any seamless fusion process.
> 4) To store computed feature points and descriptors in temporary
> metadata attached a very good and elegant way found by myself is to do
> that in an attached .HDF5 for each raster. HDF5 has the ability to
> store multidimensional data in so called "compound" types, points and
> its descriptors can be enumerated in nice and very fast way. Many
> more data's like homography matrix, or other constrains can be
> attached also into the HDF5 data in a highly organized way, and also
> there could be also room for small raster-bands (and any OSGEO suite
> can see them in native way) for debug informations like relationship's
> matrix of whole project and other usefull data for more advanced
> users. I disliked any sqlite or xml metadata afer unleashing what hdf
> formats can do.
> 5) There may be cases when so called "singleton group" will appear in
> case of n-to-n collection matching, so raster images will be divided
> in clusters with no relations between, in this case a segmentation
> over the cross-matching matrix could reveal and identify such groups,
> and OGR layer can be generated to reflect these areas.
> - I am currently doing such work for a public 3D SfM project that
> should derive 3D point-clouds from plain raster collections:
> http://code.google.com/p/featsfm, the key-points detection and
> matching parts are well implemented so far, if someone wants to
> evaluate let me know, the final code will be released around March
> anyway. Also I try to improove things in constant way, e.g. using
> recent sparse descriptors like
> http://cvlab.epfl.ch/research/detect/dbrief, extremely fast sparse
> ones that could do an a-priori co-relation job for massive datasets (>
> 10k) in first step, and in second step (after relation between pairs
> are determined) using e.g. BRISK to do a very deep co-matching of
> known pairs. Also I am experimenting a recentish MIH matcher
> http://www.cs.toronto.edu/~norouzi/research/mih instead of FLANN, it
> has the ability to mach 10k keypoints against 4M keypoints within <4s
> (nad is doint "exact" match not inexact like FLANN) but the drawback
> is that all keypoints must be present in memory at once, so need to do
> kind of "block" logic and match one image to multiple ones in single
> time but also take care to not unload and reload same parts too many
> times back&forth in memory (its trickier, need clear logistics to
> avoid duplicate matches).
> - If one wants "insane" level of post co-registration (effective
> "pixel-warp", and not affine or projective ones) there are much deeper
> post ways to go with special class of descriptors like DAISY in
> context of some statistics (bayes/markov, some papers and matlab
> implementatios where tested by me) that can do so fine co-registration
> that accurate DEM's can be extracted with ease. It is possible to
> co-register rasters taken at very different times e.g 2004winter
> 2012summer (i tried before such experiment with excelent results)
> which is consiodered very challenging, in this case a difference
> analisys is possible.
> - To have an basic idea, my own implementation of matcher do
> something like 10k vs. 10k BRISK features using FLANN in 25ms on a
> decent 2.5Ghz core, and deepest 100k vs 100k features take ~3s, very
> good timings. A simple calculs having 25ms matching time on average
> and 1000 rasters would be: 1000 * 999 / 2 * 25 ms = 3,46875 hours.
> Suite designed by me is able to derive 3D clouds out from thousands of
> hi-res UAV imagery with quite ease. Sparse DBRIEF can go way under
> <1ms per match, its a new filed to explore going "sparse" ways.
> - If interested we can improve in some ways described by me the
> proposed GDAL tool taking easy steps, so let me know, I am willing to
> contribute but need to settle the exact ways how You folks would like
> to do it in deepest details. Honestly ideas are lots where we could
> go.
> With Respect,
