[gdal-dev] gdalwarp to XYZ grid
Frank Broniewski brfr at metrico.lu
Wed Jul 3 08:01:53 PDT 2013
Am 2013-07-03 16:53, schrieb Even Rouault:
> Le mercredi 03 juillet 2013 16:17:14, Frank Broniewski a écrit :
>> Hi all,
>> I'm trying to warp a XYZ Grid to another CRS. My GDAL complains while
>> running:
>> gdalwarp -t_srs EPSG:3035 -of XYZ /tmp/tmpU7lQR2/in.xyz
>> /tmp/tmpU7lQR2/out.xyz
>>> Output driver `XYZ' not recognised or does not support
>>> direct output file creation.
> Yes, XYZ format doesn't support random write access. You need to use an
> intermediary format such as GTiff or HFA for example
> gdalwarp -t_srs EPSG:3035  /tmp/tmpU7lQR2/in.xyz temp.tif
> gdal_translate  -of XYZ temp.tif /tmp/tmpU7lQR2/out.xyz
GTiff doesn't work well, because there are always distortions at the end
of the process from the reprojection back and forth process
Meanwhile, and I could hammer myself for that, I found the hint at the
mdenoise site stating that cs2cs could be used to reproject XYZ files:
cs2cs +init=epsg:4326 +to +init=epsg:3035 03_N49E006_dn_trl_xyz.xyz >
epsg3035.xyz
does the trick ...
Frank
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
