[gdal-dev] hillshading to vector
Carlo A. Bertelli (Charta s.r.l.)
bertelli at charta.acme.com
Wed Jul 3 07:44:45 PDT 2013
Hello,
gdaldem makes a very good work and gdal_polygonize.py too, but the
combination is not so effective. Is there a way to obtain smooth polygons
representing shaded areas as it's possible with Arc? When using a dem, you
get polygons for pixels. Yes you can dissolve them, but you still have
jagged boundaries. I even tried to get contours from hillshading, but
obviously I get only polylines sometimes not useful to be transformed into
polygons.
Is there a way to get smooth polygons from gdal_polygonize or polygons from
gdal_contour?
Carlo A. Bertelli
Charta servizi e sistemi per il territorio e la storia ambientale srl
Dipendenze del palazzo Doria,
vc. alla Chiesa della Maddalena 9/2 16124 Genova (Italy)
tel. +39(0)10 2475439 fax +39(0)10 2475439 gsm:+39 393 1590711
e-mail: bertelli at charta.acme.com http://www.charta.acme.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130703/f573444c/attachment-0001.html>
