[gdal-dev] g++ compilation errors when trying to compile GDAL on Fedora 17 64bit
Daniel Kranich Daniel at nusalaska.com
Wed Jul 3 09:54:23 PDT 2013
Hello,
I have been trying to compile GDAL on my system as I would like to
enable BigTIFF support.
I got through the ./compile just fine, however the make is giving me
issues right off the start.
Here is what my make command does:
     [root at daniel-fedora gdal-1.10.0]# make
     (cd port; make)
     make[1]: Entering directory `/home/Daniel/Downloads/gdal-1.10.0/port'
     /bin/sh /home/Daniel/Downloads/gdal-1.10.0/libtool --mode=compile
--tag=CXX g++  -DOGR_ENABLED -I/home/Daniel/Downloads/gdal-1.10.0/port
      -I../frmts/zlib -DHAVE_LIBZ -c -o cpl_conv.lo
     cpl_conv.cpp
     libtool: compile:  g++ -DOGR_ENABLED
-I/home/Daniel/Downloads/gdal-1.10.0/port -I../frmts/zlib
     -DHAVE_LIBZ -c cpl_conv.cpp  -o .libs/cpl_conv.o
     /home/Daniel/Downloads/gdal-1.10.0/libtool: line 1133: g++: command
not found
     make[1]: *** [cpl_conv.lo] Error 1
     make[1]: Leaving directory `/home/Daniel/Downloads/gdal-1.10.0/port'
     make: *** [port-target] Error 2
Im not even sure where to start looking.
Thanks
-Daniel
