[gdal-dev] gdal/proj4 and gtk, SpatialReference.setFromUserInput bug
raigron at fly-n-sense.com raigron at fly-n-sense.com
Fri Jul 5 01:59:47 PDT 2013
i'm facing a strange bug in python:
from osgeo import osr
sp = osr.SpatialReference()
sp.SetFromUserInput("IGNF:LAMB2C")
print sp
returns:
PROJCS["unnamed",
     GEOGCS["unnamed ellipse",
         DATUM["unknown",
             SPHEROID["unnamed",6378249.2,293.466021],
             EXTENSION["PROJ4_GRIDS","ntf_r93.gsb,null"]],
         PRIMEM["unnamed",2.337229167],
         UNIT["degree",0.0174532925199433]],
     PROJECTION["Lambert_Conformal_Conic_1SP"],
     PARAMETER["latitude_of_origin",46.8],
     PARAMETER["central_meridian",0],
     PARAMETER["scale_factor",0.99987742],
     PARAMETER["false_easting",600000],
     PARAMETER["false_northing",2200000],
     UNIT["Meter",1]]
which is correct.
But when i import gtk :
import gtk
print sp
PROJCS["unnamed",
         DATUM["unknown",
             SPHEROID["unnamed",6378249,293],
         PRIMEM["unnamed",2],
     PARAMETER["latitude_of_origin",46],
     PARAMETER["scale_factor",0],
     UNIT["Meter",1]]
the float values seem to have been cast to integers.
I'm using
Gdal: 1.10.0
Proj: 4.8.0
Python: 2.7.5
Gtk: 2.28.6
Note that it works correctly with Proj4.7.0.
Does someone have a clue about what's happening ?
Thanks
