[gdal-dev] gdal/proj4 and gtk, SpatialReference.setFromUserInput bug
Even Rouault
even.rouault at mines-paris.org
Fri Jul 5 12:24:38 PDT 2013
> Does someone have a clue about what's happening ?
Yes,
this is due to the "import gtk" setting the locale from the C locale to the
locale of the language of your system, which has likely comma has the decimal
separator. There are a few places in GDAL/OGR that are not ready (yet) for
that.
You can workaround the issue with the following :
from osgeo import osr
import gtk
sp = osr.SpatialReference()
# Save current locale and switch to C locale
import locale
old_locale = locale.setlocale(locale.LC_ALL, None)
locale.setlocale(locale.LC_ALL, 'C')
sp.SetFromUserInput("IGNF:LAMB2C")
# Restore old locale
locale.setlocale(locale.LC_ALL, old_locale)
print sp
I'll look to do the same fix in GDAL itself.
> Thanks
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
