[gdal-dev] Automated publication of code coverage under GDAL autotest suite
Even Rouault
even.rouault at mines-paris.org
Wed Jul 10 10:13:10 PDT 2013
Hi devs,
Similarly to what I've just done with MapServer, you can find at the following
URL the continuously updated result of the code coverage under GDAL autotest suite :
http://rawgithub.com/rouault/gdalautotest-coverage-results/master/coverage_html/index.html
This is done by a Travis-CI job that runs on the following modified GIT mirror
of the GDAL svn trunk :
https://github.com/rouault/gdal_coverage
If you are curious about the details, you can read the following messages related
to my similar work on MapServer :
http://lists.osgeo.org/pipermail/mapserver-dev/2013-July/013403.html
http://lists.osgeo.org/pipermail/mapserver-dev/2013-July/013418.html
http://lists.osgeo.org/pipermail/mapserver-dev/2013-July/013424.html
Best regards,
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
