[gdal-dev] Automated publication of code coverage under GDAL autotest suite
Even Rouault even.rouault at mines-paris.org
Tue Jul 30 08:22:30 PDT 2013
some update :
I've set-up 2 new branches in the https://github.com/rouault/gdal_coverage
repository to also build & run the autotests with :
- Mac OS X : the trick is to indicate "language: objective-c" in the
.travis.yml file of the branch so that a Mac OSX 10.8 VM is used. Even if your
project is not objective-c.
- Windows with mingw/wine : a standard Travis-CI Ubuntu VM. GDAL is cross-
compiled with i586-mingw32msvc-gcc and the autotest suite is run with Win32
Python2.7 under wine ...
The summary of the branches can be seen here :
https://travis-ci.org/rouault/gdal_coverage/branches
Even
Le mercredi 10 juillet 2013 19:13:10, Even Rouault a écrit :
> Hi devs,
> Similarly to what I've just done with MapServer, you can find at the
> following URL the continuously updated result of the code coverage under
> GDAL autotest suite :
> http://rawgithub.com/rouault/gdalautotest-coverage-results/master/coverage_
> html/index.html
> This is done by a Travis-CI job that runs on the following modified GIT
> mirror of the GDAL svn trunk :
> If you are curious about the details, you can read the following messages
> related to my similar work on MapServer :
> http://lists.osgeo.org/pipermail/mapserver-dev/2013-July/013403.html
> http://lists.osgeo.org/pipermail/mapserver-dev/2013-July/013418.html
> http://lists.osgeo.org/pipermail/mapserver-dev/2013-July/013424.html
> Best regards,
> Even
Geospatial professional services
http://even.rouault.free.fr/services.html
