[gdal-dev] GRIB2 to NetCDF - Large areas of data missing
Jason Greenlaw - NOAA Affiliate
jason.greenlaw at noaa.gov
Wed Jul 17 13:31:51 PDT 2013
I am experiencing strange behavior when reprojecting/converting a GRIB2
file to NetCDF using gdalwarp, where the resulting NetCDF file is missing
lots of data (or possibly being set incorrectly to NoData) west of a
certain longitude. However, if I instead reproject from GRIB2 to an
intermediate format (e.g. GeoTIFF), then convert to NetCDF using
gdal_translate, the result is correct.
The source projection is the weather service's custom lambert conformal,
and the destination is WGS84. I'm using the following command:
gdalwarp -wm 256 -of netcdf -srcnodata 9999.0 -dstnodata 9999.0 -t_srs
EPSG:4326 conus-wspd-01.bin conus-wspd-01.nc
GDAL versions tested were 1.9.2 and 1.10.
Screenshot of original GRIB2 file (first GRIB message) as displayed in
ArcMap: http://jetstreak.unh.edu/gdal/full.png
Screenshot of resulting NetCDF file (variable Band1) as displayed in
ncBrowse: http://jetstreak.unh.edu/gdal/cropped.png
Original GRIB2 file (6.3mb): http://jetstreak.unh.edu/gdal/conus-wspd-01.bin
Resulting NetCDF file (171mb):
http://jetstreak.unh.edu/gdal/conus-wspd-01.nc
Anyone run into a similar problem or have any ideas for how to resolve this?
Thanks,
Jason
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130717/e9e37685/attachment.html>
