[gdal-dev] Call for discussion for "RFC 41 : Support for multiple geometry fields in OGR"
Andreas Neumann
a.neumann at carto.net
Wed Jul 24 07:07:49 PDT 2013
I can't comment about the technical issues. But from a user point of
view there is a need to have more than one geometry representation per
feature. There could be several generalizations attached to a feature,
or different states.
I would welcome such a feature in OGR.
I guess Swisstopo also has a specific use case in mind since they
sponsor the work. Do you know which?
Andreas
Am 24.07.2013 15:52, schrieb Howard Butler:
> On Jul 24, 2013, at 8:47 AM, Even Rouault <even.rouault at mines-paris.org> wrote:
>> Too verbose maybe ;-) , since you probably missed the (discrete) mention to
>> the OLCCreateGeomField capability (at layer level since CreateGeomField() is a
>> OGRLayer method)
> Indeed. Thanks for a thorough RFC. Now people can move on to arguing whether or not multiple geometry fields in a data source is a good idea :)
> Howard
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
