[gdal-dev] GDALRasterBand::RasterIO and FlushCache
David Strip
gdal at stripfamily.net
Sat Jun 1 20:06:40 PDT 2013
On 5/31/2013 5:38 PM, Frank Warmerdam wrote:
> Note that the image cache will start discarding blocks on it's own
> when it is full. I think the default cache is about 64MB. I don't
> think that flushing the cache should be part of normal applications
> operations, though if you are very tight on memory you might want to
> alter the default size. Note that the cached blocks are discarded
> when the dataset is closed.
Thanks - I didn't realize this as happening. My memory usage appeared to
be growing, but I didn't look that closely. A little experimentation
showed that max_cache = 40960K (at least in my build, which is pretty
much a default setup), and indeed once max cache is reached there is no
growth in the memory usage.
David
