[gdal-dev] ogr_dispatch.py: dispatch features into layers according to the value of some fields or the geometry type
Even Rouault
even.rouault at mines-paris.org
Sun Jun 2 04:07:19 PDT 2013
http://svn.osgeo.org/gdal/trunk/gdal/swig/python/samples/ogr_dispatch.py is a
new utility that can be used typically to dispatch features of datasource that
mix in a single layer features of several geometry types into separate target
layers, to match a typical constraint enforced in most GIS formats (one
geometry type per layer). You can also use it to dispatch features according
to the value of a field.
From the usage message:
ogr_dispatch.py [-f format] -src name -dst name [-field field]+
[-25D_as_2D] [-multi_as_single]
[-remove_dispatch_fields] [-prefix_with_out_lyr_name]
[-dsco KEY=VALUE]* [-lco KEY=VALUE]* [-a_srs srs_def]
[-style_as_field] [-where restricted_where] [-gt n] [-quiet]
Dispatch features into layers according to the value of some fields or their
geometry type.
Arguments:
-f format: name of the driver to use to create the destination dataset
(default 'ESRI Shapefile').
-src name: name of the source dataset.
-dst name: name of the destination dataset (existing or to be created).
-field field: name of a field to use to dispatch features. May also
be 'OGR_GEOMETRY'. At least, one occurence needed.
-25D_as_2D: for dispatching, consider 2.5D geometries as 2D.
-multi_as_single: for dispatching, consider MULTIPOLYGON as POLYGON and
MULTILINESTRING as LINESTRING.
-remove_dispatch_fields: remove the dispatch fields from the target layer
definitions.
-prefix_with_out_lyr_name: prefix the target layer name with the source layer
name.
-dsco KEY=VALUE: dataset creation option. May be repeated.
-lco KEY=VALUE: layer creation option. May be repeated.
-a_srs srs_def: assign a SRS to the target layers. Source layer SRS is
otherwise used.
-style_as_field: add a OGR_STYLE field with the content of the feature style
string.
-where restricted_where: where clause to filter source features.
-gt n: group n features per transaction (default 200).
Example :
ogr_dispatch.py -src in.dxf -dst out -field Layer -field OGR_GEOMETRY
Best regards,
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
