[gdal-dev] Non-EPSG projections, esri_extra.wkt and best practices
Tyler Mitchell
tyler.mitchell at actian.com
Mon Jun 3 09:03:25 PDT 2013
On 2013-06-03, at 8:41 AM, Jorge Arévalo wrote:
> I like the idea about append the ESRI definitions to the end of the EPSG main file. So, I guess than, in that situation, I should just replace the "ESRI" part in the string with "EPSG", right?
I guess so, I haven't done it myself, but once the definitions are in the main epsg file you would normally just use EPSG: with the new number.
Someone else may have a better idea :)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130603/ceb41d73/attachment.html>
