[gdal-dev] gdal_merge does not mosaic
adi_khan adiba.nizami at gmail.com
Tue Jun 4 02:59:21 PDT 2013
Hi All,
Could you please suggest any open source library/API/ command line tools (on
Linux) that can mosaic images of the kind I posted earlier  (with different
paramters etc..)?
Also if I am to use gdal_merge then I will have to reproject all input
images to one projcs and then try mosaicing ?
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-merge-does-not-mosaic-tp5057095p5057704.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
