[gdal-dev] gdal_merge does not mosaic
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Tue Jun 4 05:52:37 PDT 2013
adi_khan <adiba.nizami <at> gmail.com> writes:
> Hi All,
> Could you please suggest any open source library/API/ command line tools (on
> Linux) that can mosaic images of the kind I posted earlier  (with different
> paramters etc..)?
> Also if I am to use gdal_merge then I will have to reproject all input
> images to one projcs and then try mosaicing ?
You will do what you want with gdalwarp but giving remote help without a
possibility to play with same kind of images than you have is not very
productive. If you can't share your originals could it be possible to
generate some similar samples from free data?
-Jukka Rahkonen-
