[gdal-dev] Errors reading jpegs
Oyvind Idland
oyvind.idland at gmail.com
Mon Jun 24 14:03:38 PDT 2013
I got a tiled dataset from a client, consisting of 8 jpegs + jpw's.
These are used in a .vrt, and I get the following error: "IReadBlock failed
at X offset 0, Y offset 73".
I get the same errors when testing the .jpegs individually aswell. When
stepping into the GDAL code, I can see that the first band is being read,
while the second (green) fails. I didn't go any further.
When opening them in GIMP, and saving back, they work fine.
GDAL version is 1.8.0.
Here is a sample dataset that fails:
https://dl.dropboxusercontent.com/u/32561725/data.tgz
- Oyvind
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130624/31146080/attachment.html>
