[gdal-dev] Errors reading jpegs
Jean-Claude Repetto
jrepetto at free.fr
Mon Jun 24 14:57:44 PDT 2013
On 24/06/2013 23:03, Oyvind Idland wrote:
> I got a tiled dataset from a client, consisting of 8 jpegs + jpw's.
> These are used in a .vrt, and I get the following error: "IReadBlock
> failed at X offset 0, Y offset 73".
> Here is a sample dataset that fails:
> https://dl.dropboxusercontent.com/u/32561725/data.tgz
Hello,
I"m not using GDAL 1.8 anymore, but I had no problem to read neither the
JPEG file nor the VRT with GDAL 1.10.
Jean-Claude
