[gdal-dev] Errors reading jpegs
David J. Bakeman dbakeman at comcast.net
Mon Jun 24 16:20:19 PDT 2013
On 06/24/2013 02:57 PM, Jean-Claude Repetto wrote:
> On 24/06/2013 23:03, Oyvind Idland wrote:
>> I got a tiled dataset from a client, consisting of 8 jpegs + jpw's.
>> These are used in a .vrt, and I get the following error: "IReadBlock
>> failed at X offset 0, Y offset 73".
>> Here is a sample dataset that fails:
>> https://dl.dropboxusercontent.com/u/32561725/data.tgz
> Hello,
> I"m not using GDAL 1.8 anymore, but I had no problem to read neither
> the JPEG file nor the VRT with GDAL 1.10.
Same here with 1.9 I can read both no problems.
> Jean-Claude
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
