[gdal-dev] INSPIRE compliant metadata
Kralidis,Tom [Ontario]
Tom.Kralidis at ec.gc.ca
Wed Mar 6 06:59:28 PST 2013
One approach could be a script to use the GDAL/OGR libraries to generate the XML document, given that there are metadata elements that you can't derive just from the data.
..Tom
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org on behalf of laura0
Sent: Wed 06-Mar-13 08:29
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] INSPIRE compliant metadata
Hello,
I am using the GDAL Utility Program gdalinfo to report metadata about a
raster file (netCDF, grib, hdf). I would like to transform these information
collected using the inspire directive (ogc csw). Is there a tool to automate
this translation? I have found CatMDEdit but it does not support the format
(gdalinfo output) I need.
Thanks
View this message in context: http://osgeo-org.1560.n6.nabble.com/INSPIRE-compliant-metadata-tp5038779.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
