[gdal-dev] Can't build gdal in x64
Joaquim Luis jluis at ualg.pt
Mon May 13 11:29:12 PDT 2013
Mihael,
To build with nmake command line all you need (plus the uncomment of
x64) is to run the command from a command shell that has the apropriate
variables set to build for 64 bits.
For example, this is what I do to set up one 64 bits building
environment (it's called from within another batch file)
call "C:\Program Files (x86)\Microsoft Visual Studio
10.0\VC\vcvarsall.bat" amd64
Joaquim
> More info on issue: I seem to build from VS but not from command line.
> I put (to build in Win32)
> |!IFNDEF PLATFORM
> PLATFORM=WIN32
> !ENDIF|
> Modified to
> |!IFNDEF PLATFORM
> PLATFORM=x64
> !ENDIF|
> (to build in x64) - And it worked. But only if I build from inside
> Visual Studio.
> I would like to be able to use a bat file (and build alll
> platform/configurations) The above - while it builds in VS, it will
> not build from command line (with commands:
> |start/b/wait nmake-f makefile.vc clean
> start/b/wait nmake.exe/f makefile.vc PLATFORM=x64
> start/b/wait nmake.exe/f makefile.vc devinstall PLATFORM=x64|
> The exact same thing builds in Win32...
> On Mon, May 13, 2013 at 8:53 AM, Mihaela Gaspar
> <mihaela.gaspar at urbanrobotics.net
> <mailto:mihaela.gaspar at urbanrobotics.net>> wrote:
>     I am trying to build GDAL (1.9.2) in x64.
>     In the instructions, I see:
>     |# Uncomment the following if you are building for 64-bit windows
>     # (x64). You'll need to have PATH, INCLUDE and LIB set up for 64-bit
>     # compiles.
>     !IF"$(PLATFORM)"  ==  "x64"
>     WIN64=YES
>     !ENDIF|
>     And then, lower,
>     |# Under win64, symbols for function names lack the underscore prefix
>     # present on win32. Also the STDCALL calling convention is not used.
>     !IFDEF WIN64
>     !UNDEF STDCALL
>     !ELSE
>     SYM_PREFIX=_
>     !ENDIF|
>     Can't find a PATH, INCLUDE and LIB specific for x64, or anything
>     else that I should do...
>     I can build in Win32.
>     In x64,I get linker errors:
>     |LINK:  error LNK2001:  unresolved external symbol_OGRFeatureStylePuller
>     LINK:  error LNK2001:  unresolved external symbol_OSRValidate
>     gdal19.dll:  fatal error LNK1120:  74  unresolved externals|
>     Please help.
>     Thank you.
> *Mihaela Gaspar*
> *Urban Robotics Inc.**
> *Software Engineer
> 33 NW First Avenue, Suite 200 | Portland, OR 97209
> c: 971-269-9649
> mihaela.gaspar at urbanrobotics.net <mailto:mihaela.gaspar at urbanrobotics.net>
> http://www.urbanrobotics.net <http://www.urbanrobotics.net/>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130513/01b33863/attachment-0001.html>
