[gdal-dev] Wrapping with SWIG
Greg Troxel gdt at ir.bbn.com
Sat May 18 04:56:11 PDT 2013
Hank Finley <assetfx at gmail.com> writes:
> thanks for the advice, I would still like to continue with my goal, down the
> track I'm going to be using this to fuel my OpenGL graphical map. The SQL
> API level was far too slow, so I am going to the C API level.
> Is it possible to contact Even somehow?
I may have missed something, but you don't seem to have posted a
detailed explanation of what you did and what your problem is.
Generally people are more willing to help in public, because the
archived replies will help others.
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130518/9142ac2d/attachment.pgp>
