[gdal-dev] Is using geometry in SQL inside VRT supported?
Frank Warmerdam
warmerdam at pobox.com
Fri May 24 11:09:07 PDT 2013
Jukka,
I do see it mentioned there in the SrcSQL docs.
Best regards,
Frank
On Fri, May 24, 2013 at 10:46 AM, Rahkonen Jukka
<jukka.rahkonen at mmmtike.fi>wrote:
> Hi Frank,
> Great, and I guess that this syntax example about how to select the
> dialect will be added to the driver manual page
> http://www.gdal.org/ogr/drv_vrt.html in your documentation sprint of
> FOSS4G NA.
> -Jukka-
> ________________________________
> Frank Warmerdam wrote:
> Jukka,
> It turns out you can already assign a dialect. I think it is roughly like:
> <SrcSQL dialect="sqlite">SELECT ...</SrcSQL>
> It seems to be touched on it the docs for the OGR VRT driver as well.
> Best regards,
> Frank
> On Fri, May 24, 2013 at 9:46 AM, Frank Warmerdam <warmerdam at pobox.com
> <mailto:warmerdam at pobox.com>> wrote:
> Jukka,
> Agreed! The SrcSQL directive in the VRT should accept a dialect option.
> I'll try to do that this afternoon as we are "sprinting" here at FOSS4G NA
> and this would be a nice sized feature to add.
> Best regards,
> Frank
> On Fri, May 24, 2013 at 8:39 AM, Jukka Rahkonen <jukka.rahkonen at mmmtike.fi
> <mailto:jukka.rahkonen at mmmtike.fi>> wrote:
> Hi,
> This works with ogrinfo
> ogrinfo -ro cities.shp -dialect SQLITE -sql "select GEOMETRY from cities"
> I tried to make a VRT file which would do the same
> <OGRVRTDataSource>
> <OGRVRTLayer name="cities">
> <SrcDataSource>cities.shp</SrcDataSource>
> <LayerSRS>WGS84</LayerSRS>
> <SrcSQL>SELECT GEOMETRY from cities</SrcSQL>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> Now ogrinfo does not find geometries
> ogrinfo cities.vrt
> INFO: Open of `cities.vrt'
> using driver `VRT' successful.
> 1: citiesERROR 1: SQL Expression Parsing Error: syntax error
> ERROR 1: SQL statement failed, or returned no layer result:
> "SELECT GEOMETRY from cities"
> This exact use case is not at all interesting but there would be quite nice
> possibilities if Spatialite SQL queries could be fired from the VRT and all
> this would be supported for on-the-fly conversions
> http://www.gaia-gis.it/gaia-sins/spatialite-sql-4.0.0.html
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com<mailto:warmerdam at pobox.com>
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130524/e81918ee/attachment-0001.html>
