[gdal-dev] Slow convertion from OSM to PG with -skipfailures
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Mon May 27 07:47:09 PDT 2013
I have measured a huge speed difference by running the same conversion from
OSM data file into PostGIS either with or without using the -skipfailures
parameter.
Without -skipfailures conversion takes about two minutes but if I add the
parameter it takes at least two hours. The command I used is this
ogr2ogr -f PostgreSQL PG:"dbname='gis' host='server' port='4326' user='user'
password='passwd'" finland.osm.pbf -gt 20000 -progress
--config OSM_COMPRESS_NODES YES -lco DIM=2 -lco geometry_name=geoloc
-lco fid=fid -skipfailures --config PG_USE_COPY YES
I wonder if it really needs to be so slow. My guess is that -skipfailures
somehow invalidates my -gt 20000 parameter.
-Jukka Rahkonen-
