[gdal-dev] Slow convertion from OSM to PG with -skipfailures
    Even Rouault
    even.rouault at mines-paris.org
    Mon May 27 08:12:45 PDT 2013
Selon Jukka Rahkonen <jukka.rahkonen at mmmtike.fi>:
> Hi,
> I have measured a huge speed difference by running the same conversion from
> OSM data file into PostGIS either with or without using the -skipfailures
> parameter.
> Without -skipfailures conversion takes about two minutes but if I add the
> parameter it takes at least two hours. The command I used is this
> ogr2ogr -f PostgreSQL PG:"dbname='gis' host='server' port='4326' user='user'
> password='passwd'" finland.osm.pbf -gt 20000 -progress
> --config OSM_COMPRESS_NODES YES  -lco DIM=2 -lco geometry_name=geoloc
> -lco fid=fid -skipfailures  --config PG_USE_COPY YES
> I wonder if it really needs to be so slow. My guess is that -skipfailures
> somehow invalidates my -gt 20000 parameter.
Yes, it does. In -skipfailures mode, the transaction must be per feature, so
that a failure on a feature doesn't impact other features.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
