Hi, with gdal 1.9.2 when passing to ogr2ogr the layer names to import ( interlis 1 driver ) some layers could not be found. Instead when importing the whole file everything is OK. The ili file contains 109 layers. Is there some limitations on the arguments length? Thanks. Regards, Mario Jurcevic
