[gdal-dev] gdal_merge does not mosaic
adi_khan
adiba.nizami at gmail.com
Thu May 30 22:36:50 PDT 2013
I am using gdal 1.4.5 and wish to use gdal_merge to mosaic *.img images.
The command runs successfully (no error is reported) but the output file
contains the last input image and not mosaiced output.
I use openEV to see the output file.
This is how is used the command :
gdal_merge.py -of HFA -o mosaic.img img1.img img2.img img3.img
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-merge-does-not-mosaic-tp5057095.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
