[gdal-dev] gdal_merge does not mosaic
Etienne Tourigny
etourigny.dev at gmail.com
Fri May 31 07:46:27 PDT 2013
Update to gdal 1.9 and try again.
On Fri, May 31, 2013 at 2:36 AM, adi_khan <adiba.nizami at gmail.com> wrote:
> I am using gdal 1.4.5 and wish to use gdal_merge to mosaic *.img images.
> The command runs successfully (no error is reported) but the output file
> contains the last input image and not mosaiced output.
> I use openEV to see the output file.
> This is how is used the command :
> gdal_merge.py -of HFA -o mosaic.img img1.img img2.img img3.img
> http://osgeo-org.1560.x6.nabble.com/gdal-merge-does-not-mosaic-tp5057095.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130531/807d74f0/attachment.html>
