[gdal-dev] Skipping PHOTOMETRIC=YCBCR when not reasonable
Even Rouault even.rouault at mines-paris.org
Fri Nov 1 08:06:04 PDT 2013
Le vendredi 01 novembre 2013 15:56:39, Rahkonen Jukka a écrit :
> Hi,
> Yes, it is understandable because there are so many parameters which may be
> wrong. I still don't write any other scripts than Windows batch files and
> testing the return codes is not my business. I will continue by sorting
> the source files as well as I can and running the batch a second time
> without YCBCR for the images which were not converted with the first run.
> Not a big problem for me really.
Should be something like the following (untested)
gdal_translate src.tif out.tif -co PHOTOMETRIC=YCBCR
if %ERRORLEVEL% == 0 (
   echo Conversion successfull
) else (
   echo Retrying without YCBCR
> -Jukka-
> Even Rouault wrote:
> > Jukka,
> > It is difficult to guess if the option specified by the user is something
> > that he wants absolutely to be honoured (and in case it is not possible,
> > an error is expected), or if it is just a hint that can be ignored if
> > necessary. So the current behaviour seems OK to me.
> > Your script could just test the return code of gdal_translate and, in
> > case of error, try again without -co PHOTOMETRYC=YCBCR. Or check before
> > if the input dataset is 3 bands or not.
> > Even
> > > Hi,
> > > Gdal_translate throws
> > > ERROR 6: PHOTOMETRIC=YCBCR requires a source raster with only 3 bands
> > > (RGB) if user tries to apply YCBCR to non-RGB image. It means that
> > > when I have a mixture of RGB and B/W images I must separate them
> > > before making batch jobs.
> > > I think that nothing bad would happen if gdal_translate in such case
> > > just throws a warning and continues by compressing black and white
> > > image with the default photometric settings.
> > > -Jukka Rahkonen-
> > > _______________________________________________
> > > gdal-dev mailing list
> > > gdal-dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > Geospatial professional services
> > http://even.rouault.free.fr/services.html
