[gdal-dev] geotiff projection not showing up
Wed Nov 6 13:51:17 PST 2013
Norman,
I believe you want to call SetGCPProjection() instead of SetProjection()
when using GCPs instead of an affine transform.
Best regards,
Frank
On Wed, Nov 6, 2013 at 1:23 PM, Norman Goldstein <normvcr at telus.net> wrote:
> I have created a geotiff file using the "GTiff" driver, and have
> successfully set options for it to be a strips file with no compression.
>  Also, successfully called the functions
> dataset->SetMetadataItem( "AREA_OR_POINT",
>                                             "Point",
>                                              nullptr ) )
> and
> dataset->SetGCPs( 3,
>                                gcps,
>                                "Richmond" )
> Here is the listgeo dump:
> ############# listgeo dump ##############
> Geotiff_Information:
>    Version: 1
>    Key_Revision: 1.0
>    Tagged_Information:
>       ModelTiepointTag (6,3):
>          0                249              0
>          0                0                0
>          399              249              0
>          1000             0                0
>          0                0                0
>          0                2000             0
>       End_Of_Tags.
>    Keyed_Information:
>       GTRasterTypeGeoKey (Short,1): RasterPixelIsPoint
>       End_Of_Keys.
>    End_Of_Geotiff.
> Corner Coordinates:
>  ... unable to transform points between pixel/line and PCS space
> I also set the reference system using the following code:
> /////////////////////// c++ code ////////////////////////////
>   OGRSpatialReference oSRS;
>   oSRS.SetProjCS( "NoWhere" );
>   oSRS.SetWellKnownGeogCS( "WGS84" );
>   oSRS.SetEquirectangular( 0.0,        // Centre lat
>                0.0,        // Centre lon
>                0.0,   // False Easting
>                0.0 ); // False Northing
>   char* wkt = nullptr;
>   if( OGRERR_NONE != oSRS.exportToPrettyWkt( &wkt ) )
>      error...
>   if( CE_Failure == dataset->SetProjection( wkt ) )
>    error...
> So, why is listgeo not able to transform points between pixel/line and PCS
> space?
> I am happy to upload a full working example if needed.
> Thank you.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131106/95d925b4/attachment-0001.html>
