[gdal-dev] geotiff projection not showing up
Norman Goldstein
normvcr at telus.net
Wed Nov 6 16:00:12 PST 2013
Frank,
I am using GDAL
Version : 1.9.2
so maybe that is why I do not see the method SetGCPProjection().
I think you have convinced me, though, to calculate the 6 coefficients
directly,
and then call SetGeoTransform(). Will let you guys know how this works out
for me.
Thank you,
Norm
On 11/06/2013 01:51 PM, Frank Warmerdam wrote:
> Norman,
> I believe you want to call SetGCPProjection() instead of
> SetProjection() when using GCPs instead of an affine transform.
> Best regards,
> Frank
> On Wed, Nov 6, 2013 at 1:23 PM, Norman Goldstein <normvcr at telus.net
> <mailto:normvcr at telus.net>> wrote:
> I have created a geotiff file using the "GTiff" driver, and have
> successfully set options for it to be a strips file with no
> compression. Also, successfully called the functions
> dataset->SetMetadataItem( "AREA_OR_POINT",
> "Point",
> nullptr ) )
> and
> dataset->SetGCPs( 3,
> gcps,
> "Richmond" )
> Here is the listgeo dump:
> ############# listgeo dump ##############
> Geotiff_Information:
> Version: 1
> Key_Revision: 1.0
> Tagged_Information:
> ModelTiepointTag (6,3):
> 0 249 0
> 0 0 0
> 399 249 0
> 1000 0 0
> 0 0 0
> 0 2000 0
> End_Of_Tags.
> Keyed_Information:
> GTRasterTypeGeoKey (Short,1): RasterPixelIsPoint
> End_Of_Keys.
> End_Of_Geotiff.
> Corner Coordinates:
> ... unable to transform points between pixel/line and PCS space
> I also set the reference system using the following code:
> /////////////////////// c++ code ////////////////////////////
> OGRSpatialReference oSRS;
> oSRS.SetProjCS( "NoWhere" );
> oSRS.SetWellKnownGeogCS( "WGS84" );
> oSRS.SetEquirectangular( 0.0, // Centre lat
> 0.0, // Centre lon
> 0.0, // False Easting
> 0.0 ); // False Northing
> char* wkt = nullptr;
> if( OGRERR_NONE != oSRS.exportToPrettyWkt( &wkt ) )
> error...
> if( CE_Failure == dataset->SetProjection( wkt ) )
> error...
> So, why is listgeo not able to transform points between pixel/line
> and PCS space?
> I am happy to upload a full working example if needed.
> Thank you.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com <mailto:warmerdam at pobox.com>
> light and sound - activate the windows | http://pobox.com/~warmerdam
> <http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131106/48fd08a5/attachment.html>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131106/48fd08a5/attachment.bin>
