[gdal-dev] (no subject)
Fri Nov 8 13:34:36 PST 2013
Phelippe,
There are a few ways we could move forward on this.
I believe the apparent master version of the PCIDSK SDK from GDAL's point
of view is:
  http://svn.osgeo.org/gdal/sandbox/warmerdam/pcidsk
And I think the process I used before was to periodally migrate this into
the GDAL tree at:
  http://svn.osgeo.org/gdal/trunk/gdal/frmts/pcidsk/sdk/
Approaches:
1) You just drop a code dump on us, and existing developers integrate it.
2) We arrange commit access for you and you prepare an updated SDK in the
"sandbox" area in SVN.  We could then migrate that into the GDAL PCIDSK
driver itself when we are comfortable with it.
3) We arrange full commit access for you and you do your integration
directly in GDAL itself.
I prefer option (2) which avoids the likely breakage in GDAL that might
come from a wholesale replacement of the existing inside-GDAL code.  But
those who wish can still built against the standalone SDK for testing
purposes and so forth.  I'd imagine I'd be the GDAL developer to help move
things over eventually.
If you are ok with (2) then please create an OSGeo at:
  http://www.osgeo.org/osgeo_userid/
And I'll try to arrange sandbox-only commit access for you.
Best regards,
Frank
On Fri, Nov 8, 2013 at 12:19 PM, Phelippe Neveu <neveu at pcigeomatics.com>wrote:
>  To whom it may concern,
>  We have updates to the PCIDSK library that we would like to upstream to
> GDAL.
>  We have fixed numerous bugs, we have done many optimizations, and we
> also implemented a new binary tile directory.
>  How should we proceed with the upstream?
>  Thanks,
>  Phelippe
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131108/0f3ce6d2/attachment.html>
