[gdal-dev] RFC 44: JSON/XML output for ogrinfo/gdalinfo
Etienne Tourigny etourigny.dev at gmail.com
Tue Nov 19 09:31:21 PST 2013
You might think of adding json/xml output also to gdalsrsinfo, it should
not be much work.
For example, if you have a <srs> node output by gdalsrsinfo, you could have
the same (and only) node in gdalsrsinfo.  Also consider that there are
various output formats for srs (mostly in gdalsrsinfo, but also proj4 for
gdalinfo).
cheers
Etienne
On Tue, Nov 19, 2013 at 2:42 PM, Howard Butler <howard at hobu.co> wrote:
> All,
> Dan Little and myself would like to put forward an RFC proposing -xml and
> -json output support for both ogrinfo and gdalinfo. No changes are proposed
> to the current text format (which would continue to be the default output
> format), but having JSON and XML available would greatly ease the
> integration of gdalinfo and ogrinfo into existing processing workflows
> without requiring that someone jump into scripting land. Though it might
> have been overkill to have an RFC, I thought it would be useful to have
> something to collaborate on if others have ideas about these particular
> features.
> http://trac.osgeo.org/gdal/wiki/rfc44_gdalinfoxml
> We look forward to your feedback,
> Howard
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131119/a4a08413/attachment-0001.html>
