[gdal-dev] Force application of ntv2 grid
Andre Joost
andre+joost at nurfuerspam.de
Fri Nov 29 07:07:34 PST 2013
Am 29.11.2013 09:59, schrieb Jeremy Palmer:
> Hi gdal-devs,
> I'm trying to shift shapefile data using a custom NTv2 grid file. The
> logical source and destination coordinate systems are the same
> (geographic coordinates EPSG:4167), I only want to shift the data.
> The type of command I'm trying to run is:
> ogr2ogr -f "Esri Shapefile" -a_srs "+proj=longlat +ellps=GRS80"
> -t_srs "+proj=longlat +ellps=GRS80 +nadgrids=custom_grid.gsb +wktext"
> dst_datasource_name src_datasource_name
> but the output shapefile does not get transformed...
> Is this because there is a short circuit in proj4 if the ellipsoids
> are the same?
No, you have to explicitely specify +towgs84=0,0,0,0,0,0,0 for the first
srs. Otherwise it is assumed that both share the same datum.
HTH,
André Joost
