[gdal-dev] EPSG 8.2 Upgrade
Paul Meems bontepaarden at gmail.com
Thu Oct 3 09:06:12 PDT 2013
Thanks Even,
That patch works great.
Hopefully it will get implemented soon.
Paul
 *Paul Meems *
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl
2013/10/3 Even Rouault <even.rouault at mines-paris.org>
> Selon Paul Meems <bontepaarden at gmail.com>:
> > I'm not sure if this is the correct place to report this. If not please
> let
> > me know.
> > I'm having trouble compiling the trunk version of PROJ.4 with the updated
> > EPSG 8.2 database definitions.
> > I'm running Win7 and use VS2008.
> > I'm getting these errors and warnings:
> > Warning  1    Command line warning D9002 : ignoring unknown option '/Op'
> > cl
> > Warning  2    warning C4129: 'P' : unrecognized character escape
> > sequence    pj_open_lib.c
> > Warning  3    warning C4129: 'S' : unrecognized character escape
> > Error    4    error C2143: syntax error : missing ';' before 'type'
> > PJ_healpix.c
> > Error    5    error C2143: syntax error : missing ';' before 'type'
> > PJ_healpix.c
> > Error    6    error C2065: 'xc' : undeclared identifier    PJ_healpix.c
> > Error    7    error C2065: 'xc' : undeclared identifier    PJ_healpix.c
> > Error    8    error C2065: 'tau' : undeclared identifier    PJ_healpix.c
> > Error    9    error C2065: 'tau' : undeclared identifier    PJ_healpix.c
> > When I use the zipped source code for v4.8.0 I don't have these problems.
> > Can anybody assist?
> There's a patch pending in Trac for the MSVC compilation issues :
> http://trac.osgeo.org/proj/ticket/223
> > Thanks,
> > Paul
> > 2013/10/2 Frank Warmerdam <warmerdam at pobox.com>
> > > Folks,
> > > I have upgraded libgeotiff, GDAL and PROJ.4 trunk's with
> > > the EPSG 8.2 database definitions.   I have come to the
> > > conclusion that the EPSG Postgresql .sql files are distributed
> > > in WIN1252 encoding, not LATIN1, and so some special
> > > characters - mostly in comments - should be translated better.
> > > Let me know if you see problems or have questions.
> > > Best regards,
> > > I set the clouds in motion - turn up   | Frank Warmerdam,
> > > light and sound - activate the windows | http://pobox.com/~warmerdam
> > > and watch the world go round - Rush    | Geospatial Software Developer
> > > _______________________________________________
> > > gdal-dev mailing list
> > > gdal-dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131003/a8a0b003/attachment-0001.html>
