[gdal-dev] EPSG 8.2 Upgrade
Thu Oct 3 09:19:13 PDT 2013
Patch applied in trunk...
On Thu, Oct 3, 2013 at 9:06 AM, Paul Meems <bontepaarden at gmail.com> wrote:
> Thanks Even,
> That patch works great.
> Hopefully it will get implemented soon.
> Paul
>  *Paul Meems *
> Release manager, configuration manager
> and forum moderator of MapWindow GIS.
> www.mapwindow.org
> Owner of MapWindow.nl - Support for
> Dutch speaking users.
> www.mapwindow.nl
> 2013/10/3 Even Rouault <even.rouault at mines-paris.org>
>> Selon Paul Meems <bontepaarden at gmail.com>:
>> > I'm not sure if this is the correct place to report this. If not please
>> let
>> > me know.
>> > I'm having trouble compiling the trunk version of PROJ.4 with the
>> updated
>> > EPSG 8.2 database definitions.
>> > I'm running Win7 and use VS2008.
>> > I'm getting these errors and warnings:
>> > Warning  1    Command line warning D9002 : ignoring unknown option '/Op'
>> > cl
>> > Warning  2    warning C4129: 'P' : unrecognized character escape
>> > sequence    pj_open_lib.c
>> > Warning  3    warning C4129: 'S' : unrecognized character escape
>> > Error    4    error C2143: syntax error : missing ';' before 'type'
>> > PJ_healpix.c
>> > Error    5    error C2143: syntax error : missing ';' before 'type'
>> > PJ_healpix.c
>> > Error    6    error C2065: 'xc' : undeclared identifier    PJ_healpix.c
>> > Error    7    error C2065: 'xc' : undeclared identifier    PJ_healpix.c
>> > Error    8    error C2065: 'tau' : undeclared identifier    PJ_healpix.c
>> > Error    9    error C2065: 'tau' : undeclared identifier    PJ_healpix.c
>> > When I use the zipped source code for v4.8.0 I don't have these
>> problems.
>> > Can anybody assist?
>> There's a patch pending in Trac for the MSVC compilation issues :
>> http://trac.osgeo.org/proj/ticket/223
>> > Thanks,
>> > Paul
>> > 2013/10/2 Frank Warmerdam <warmerdam at pobox.com>
>> > > Folks,
>> > > I have upgraded libgeotiff, GDAL and PROJ.4 trunk's with
>> > > the EPSG 8.2 database definitions.   I have come to the
>> > > conclusion that the EPSG Postgresql .sql files are distributed
>> > > in WIN1252 encoding, not LATIN1, and so some special
>> > > characters - mostly in comments - should be translated better.
>> > > Let me know if you see problems or have questions.
>> > > Best regards,
>> > > I set the clouds in motion - turn up   | Frank Warmerdam,
>> > > light and sound - activate the windows | http://pobox.com/~warmerdam
>> > > and watch the world go round - Rush    | Geospatial Software Developer
>> > > _______________________________________________
>> > > gdal-dev mailing list
>> > > gdal-dev at lists.osgeo.org
>> > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131003/7f869b94/attachment.html>
