[gdal-dev] GDal with CMake
Dmitriy Baryshnikov bishop.dev at gmail.com
Sat Oct 5 13:08:48 PDT 2013
I'm working on CMake for GDAL. Not all drivers implemented yet, but work
is going on.
See https://github.com/aashish24/gdal-svn
Cmake4gdal branch,
why duplicate the work? I don't understand.
Best regards,
     Dmitriy
05.10.2013 14:44, Sumit Kumar ?????:
> Dear All
> I was searching for a clean implementation to build GDal using CMake.
> Barring a project started by Aashish a couple of years ago, and a trac
> page listing the need for building such an implementation
> (http://trac.osgeo.org/gdal/wiki/CMake), I could not find anything.
> I have placed a first version of a cleaner way to build GDal with
> CMake on github
> https://github.com/skn123/-gdal_cmake
> Currently, I have the following issues with this build structure and
> would solicit help from other developers in modularizing it:
> a.) The use of global if-def's makes the project highly non-modular;
> More so if we want to add support for other formats (e.g., in the
> frmts folder), we will trigger a rebuild of the entire library
> b.) Currently, this build has been tested on Visual Studio 2010 and
> 2012 64Bit. It would be nice if users can report their build
> experiences on Linux and OsX.
> c.) For now, OpenCL and Hdf5 are supported as 3rd party libraries.
> Thanks and Regards
> Sumit
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131006/8977e071/attachment.html>
