[gdal-dev] Call for discussion for "RFC 42: OGR Layer laundered field lookup"
Tamas Szekeres szekerest at gmail.com
Sun Oct 6 13:21:52 PDT 2013
Hi Jürgen,
The commit you're referring to, doesn't seem contain the handling of the
bExactMatch parameter at the driver. At the moment I consider this a bit
redundant if calling OGRLayer::FindFieldIndex with bExactMatch = TRUE does
the same as OGRLayer::GetFieldIndex. In this regard I'd be in favour of
using the same signature for both functions. In ogr2ogr we could then do
something like:
int iDstField = bExactFieldNameMatch?
poDstLayer->GetFieldIndex(poSrcFieldDefn->GetNameRef()) :
poDstLayer->FindFieldIndex(poSrcFieldDefn->GetNameRef());
Best regards,
Tamas
2013/10/6 Jürgen E. <jef at norbit.de>
> Hi Tamas,
> On Sun, 06. Oct 2013 at 20:05:18 +0200, Tamas Szekeres wrote:
> >    Looks like a good proposal.
> >    The only thing I'm uncertain about whether the driver should do
> something
> >    different when calling OGRLayer::FindFieldIndex with bExactMatch =
> TRUE
> >    than when calling OGRLayer::GetFieldIndex? I don't see the driver
> >    implementation in the pull request which would probably make that
> thing
> >    more trivial to understand.
> The pull request only has an implementation for the OCI driver:
> https://github.com/jef-n/gdal/commit/66723a4bb75c5aa1afd309420bc563e1a48b074b#diff-156f2c76948ed9a6134f385f35e83165R495
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> QGIS PSC member (RM)                                   IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131006/265e67e6/attachment.html>
