[gdal-dev] OGRLayer.Intersection() question
Tamas Szekeres szekerest at gmail.com
Sat Oct 12 09:47:09 PDT 2013
Setting the options parameter seems to be working for me (modified the sample
app<http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/csharp/apps/OGRLayerAlg.cs>to
allow this).
The issue you mentioned might be dedicated to the implementation of
Layer.Intersection
itself (I'm not too familiar in) and not to the c# interface. If you can
share sample source files to reproduce this, I might be able to provide
more specific details.
Tamas
2013/10/11 Dheeraj Reddy Mamidi <drmamidi at rothwellgroup.com>
> Hi Tamas,
> I was working with OsGeo.OGR.Layer.Intersection c# bindings and have
> problems with setting string[] of options. The intersection of layers are
> creating some invalid geometries to write in to intersected layer (Error is
> thrown -  ApplicationException was unhandled - Attempt to write non-polygon
> (GEOMETRYCOLLECTION) geometry to POLYGON type shapefile). I read the
> documentation and saw options can be enabled like SKIP_FAILURES=YES  to
> skip and continue if feature cannot be inserted, but setting option the
> way I did below to skip still throws the above error.
> string[] options = new string[] {"SKIP_FAILURES=YES"};
> layerOriginal.Intersection(layerToIntersect, intersectedLayer, options,
>  new Ogr.GDALProgressFuncDelegate(ProgressFunc), "Intersection");
> Can you help me figure out how to set the options parameter to
> Intersection method ? Thank you.
> Thanks,
> Dheeraj
> On Fri, Oct 11, 2013 at 11:25 AM, Dheeraj Reddy Mamidi <
> drmamidi at rothwellgroup.com> wrote:
>> Tamas,
>> You are right. Output shapefile cannot have mixed geometries in the same
>> file. But two input shapefiles (layers) can be of different geometries
>> types to perform operations like intersection.
>> Thanks,
>> Dhheraj
>> On Fri, Oct 11, 2013 at 11:19 AM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>> You may probably leave this checking out, I 'm not sure about all
>>> aspects of these functions. Actually the output file is a shapefile which
>>> doesn't support mixed geometries in the same file.
>>> Tamas
>>>> Tamas,
>>>> Thank you very much for fixing the issue so quickly! I really
>>>> appreciate it. That really saved lot of time for me to figure out what was
>>>> wrong.
>>>> One thing that I would like to discuss is with regards to
>>>> http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/csharp/apps/OGRLayerAlg.cs (sample
>>>> application).
>>>> Line 108:
>>>> if (layer1.GetLayerDefn().GetGeomType() !=
>>>> layer2.GetLayerDefn().GetGeomType())
>>>>           Console.WriteLine("FAILURE: Geometry type doesn't match");
>>>>           System.Environment.Exit(-1);
>>>> In the above line where you check if geometry type of layer1 and layer2
>>>> are equal, If not equal you say Geometry type do not match. I was wondering
>>>> layer geometry types can be different (eg a polygon shapefile and polyline
>>>> shapefile etc) to do intersection right ?
>>>> Thanks,
>>>> Dheeraj
>>>> On Fri, Oct 11, 2013 at 3:19 AM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>>>> Dheeraj,
>>>>> The issue is now fixed in trunk and branch-1-10 (check out the latest
>>>>> sources)
>>>>> I've also added a sample application for these methods:
>>>>> Best regards,
>>>>> Tamas
>>>>> 2013/10/10 Dheeraj Reddy Mamidi <drmamidi at rothwellgroup.com>
>>>>>> Tamas,
>>>>>> I appreciate you adding a ticket for this issue. Thanks. Is there any
>>>>>> other option for me to use OGRLayer intersection with out C# bindings for
>>>>>> now ?
>>>>>> Thanks,
>>>>>> Dheeraj
>>>>>> On Thu, Oct 10, 2013 at 2:21 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>>>>>> Dheeraj,
>>>>>>> I noticed you are talking about the layer level geometry functions,
>>>>>>> which hasn't been updated in the C# bindings yet. I'll add the necessary
>>>>>>> implementation shorly. Also added a ticket to track the changes:
>>>>>>> http://trac.osgeo.org/gdal/ticket/5264
>>>>>>> Best regards,
>>>>>>> Tamas
>>>>>>>> Tamas,
>>>>>>>> Sorry the sample code had wrong data source names. Here is the
>>>>>>>> corrected sample code..
>>>>>>>> var spatialReference = new OSGeo.OSR.SpatialReference("");
>>>>>>>> spatialReference.ImportFromProj4("+proj=longlat +ellps=WGS84
>>>>>>>> +datum=WGS84 +no_defs");
>>>>>>>> var driver = OSGeo.OGR.Ogr.GetDriverByName("ESRI Shapefile");
>>>>>>>> DataSource dataSourceToIntersectOn =
>>>>>>>> driver.Open(@"C:\Temp\gdal_32\Polygon.shp", 0);
>>>>>>>> Layer
>>>>>>>> layerToIntersectOn = dataSourceToIntersectOn.GetLayerByIndex(0);
>>>>>>>> DataSource dataSourceToIntersect =
>>>>>>>> driver.Open(@"C:\Temp\gdal_32\Polyline.shp", 0);
>>>>>>>> Layer layerToIntersect = dataSourceToIntersect.GetLayerByIndex(0);
>>>>>>>> var intersectedShapeData =
>>>>>>>> driver.CreateDataSource(@"C:\Temp\gdal_32", new string[] { });
>>>>>>>> wkbGeometryType wkbGeometryType =
>>>>>>>> layerOriginal.GetLayerDefn().GetGeomType();
>>>>>>>> Layer intersectedLayer =
>>>>>>>> intersectedShapeData.CreateLayer("intersection", spatialReference,
>>>>>>>> wkbGeometryType, new string[] { });
>>>>>>>> OSGeo.OGR.SWIGTYPE_p_void callback_data = new
>>>>>>>> OSGeo.OGR.SWIGTYPE_p_void(new IntPtr(5), false, layerToIntersect);
>>>>>>>> OSGeo.OGR.SWIGTYPE_p_GDALProgressFunc callback = new
>>>>>>>> SWIGTYPE_p_GDALProgressFunc(new IntPtr(5), false, layerToIntersect);
>>>>>>>> layerToIntersect.Intersection(layerToIntersectOn, intersectedLayer,
>>>>>>>> new string[] { "SKIP_FAILURES=YES" }, callback, callback_data); // Line
>>>>>>>> where it fails
>>>>>>>> Thanks,
>>>>>>>> Dheeraj
>>>>>>>> On Thu, Oct 10, 2013 at 1:16 PM, Dheeraj Reddy Mamidi <
>>>>>>>>> Hi Tamas,
>>>>>>>>> Thanks for your response. In fact I don't require progress
>>>>>>>>> notification, but I am not able to ignore those arguments (pass them as
>>>>>>>>> null). If I pass them as null I get error "Attempt to dereference
>>>>>>>>> null GDALProgressFunc". If I just pass those arguments
>>>>>>>>> initializing them they way I am doing below in the sample code, I get  "Attempted
>>>>>>>>> to read or write protected memory. This is often an indication that other
>>>>>>>>> memory is corrupt." error.
>>>>>>>>> I am using Gdal 1.10 library.
>>>>>>>>> Here is the sample code..
>>>>>>>>> Layer layerToIntersectOn =
>>>>>>>>> dataSourceCookieCutter.GetLayerByIndex(0);
>>>>>>>>> Layer layerToIntersect = dataSourceOriginal.GetLayerByIndex(0);
>>>>>>>>> intersectedLayer, new string[] { "SKIP_FAILURES=YES" }, callback,
>>>>>>>>> callback_data); // Line where it fails
>>>>>>>>> The data that I am trying to intersect (shapefiles are attached).
>>>>>>>>> Thanks,
>>>>>>>>> Dheeraj
>>>>>>>>> On Thu, Oct 10, 2013 at 12:33 PM, Tamas Szekeres <
>>>>>>>>> szekerest at gmail.com> wrote:
>>>>>>>>>> Dheeraj,
>>>>>>>>>> I don't think the OSGeo.OGR.Layer.Intersection supports progress
>>>>>>>>>> notification. You might probably have encountered a bug which should be
>>>>>>>>>> fixed. Do you have a sample code to reproduce this issue? I would
>>>>>>>>>> specifically interested in the actual geometries have been passed to the
>>>>>>>>>> function.
>>>>>>>>>> Best regards,
>>>>>>>>>> Tamas
>>>>>>>>>>> Hi list,
>>>>>>>>>>>  I have troubles with C# bindings of OGR. I was trying to
>>>>>>>>>>> perform intersection on two feature classes (shape file formats) using
>>>>>>>>>>> OSGeo.OGR.Layer.Intersection(), but have problems making it work. I
>>>>>>>>>>> keep getting an error saying "AccessViolationException was
>>>>>>>>>>> unhandled. Attempted to read or write protected memory. This is often an
>>>>>>>>>>> indication that other memory is corrupt.
>>>>>>>>>>> Is the above error something to do with SWIGTYPE_p_GDALProgressFunc
>>>>>>>>>>> callback and OSGeo.OGR.SWIGTYPE_p_void callback_data arguments? I
>>>>>>>>>>> tried passing those parameters null as suggested by some in the forums butI keep getting the error "Attempt to dereference
>>>>>>>>>>> null GDALProgressFunc". I am not sure what that means.
>>>>>>>>>>> And when I instantiate callback as new SWIGTYPE_p_GDALProgressFunc()
>>>>>>>>>>> and new callback_data as new SWIGTYPE_p_void(), I don't get error Attempt
>>>>>>>>>>> to dereference null GDALProgressFunc, but still have error
>>>>>>>>>>> saying AccessViolationException was unhandled. Attempted to
>>>>>>>>>>> memory is corrupt.
>>>>>>>>>>> Can someone please help me figure this out and let me know how
>>>>>>>>>>> to make use of OSGeo.OGR.Layer.Intersection() in the right way
>>>>>>>>>>> with c# bindings. Thank you.
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Dheeraj
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> gdal-dev mailing list
>>>>>>>>>>> gdal-dev at lists.osgeo.org
>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>>> Software Developer
>>>>>> The Rothwell Group, L.P.
>>>>>> Email: drmamidi at rothwellgroup.com <atvaughan at rothwellgroup.com>
>>>>>> Phone: 713-952-5355 ext.30
>>>>>> Web: www.rothwellgroup.com
>>>> Software Developer
>> Software Developer
> Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131012/7e4e1982/attachment-0001.html>
