[gdal-dev] GDAL 1.10.1 requirements
laura0
lauramail at iol.it
Mon Oct 14 01:54:59 PDT 2013
Hi all,
I would like to know which versions of netcdf, hdf4, hdf5 libraries are
supported by the new release of GDAL.
I tried for instance 4.1.1 netcdf library but, after ./configure, I see
"netcdf supported NO" . So I think that version is too old. With the latest
versions (netcdf 4.3.0, hdf5 1.8.11 , hdf4 4.2.9 ) everything looks going
fine but processing an hdf5 dataset I got the following error:
HDF5-DIAG: Error detected in HDF5 (1.8.11) thread 0:
#000: H5A.c line 557 in H5Aopen(): unable to load attribute info from
object header for attribute: 'PRODUCT_NAME'
major: Attribute
I was able to open the same dataset instead with gdal 1.9 and library
versions: hdf5 1.8.9 , hdf4 4.2.8 , netcdf 4.2.1.1
Is it a problem of versions or something else?
Many thanks,
regards
Laura
View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-1-10-1-requirements-tp5083369.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
