[gdal-dev] Sharing GDAL Dataset objects between threads (JNI)
Markus Schneider schneider at occamlabs.de
Mon Oct 14 04:16:49 PDT 2013
Hi Even,
Am 14.10.2013 13:10, schrieb Even Rouault:
> This is surprising. Are you seeing that with a particular driver or all drivers
I am experiencing this with ECW driver.
> I don't see any use of TLS on the Java side. There might be some use of TLS
> objects on the C side, for functions in cpl_path.cpp for example, but their use
> should be limited to the lifetime of the execution of a particular function, so
> that shouldn't cause problems in the scenario you describe.
I will try to prepare a minimal example to reproduce the issue. I will
also check if it occurs with a GeoTIFF.
>> Would it be hard to eliminate this behaviour (as it
>> would make pooling Dataset objects much easier and more efficient)?
> Difficult to tell until we have understood what really happens...
> Do you manage to reproduce that by running under Valgrind ? If so, that might
> help understanding what is going wrong.
I never used Valgrind, but with some help, I may be able to check
behaviour and report.
Best regards,
Markus
Markus Schneider
CEO
Occam Labs UG (haftungsbeschränkt)
Godesberger Allee 139
53175 Bonn, Germany
+49 228 93798874
http://www.occamlabs.de
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131014/17730348/attachment.pgp>
