[gdal-dev] Sharing GDAL Dataset objects between threads (JNI)
Even Rouault
even.rouault at mines-paris.org
Mon Oct 14 04:26:17 PDT 2013
Selon Markus Schneider <schneider at occamlabs.de>:
> Hi Even,
> Am 14.10.2013 13:10, schrieb Even Rouault:
> > This is surprising. Are you seeing that with a particular driver or all
> drivers
> I am experiencing this with ECW driver.
Ah, well, anything can happen within the beast then... Which SDK version : 3.3
or 5 ?
> > I don't see any use of TLS on the Java side. There might be some use of TLS
> > objects on the C side, for functions in cpl_path.cpp for example, but their
> use
> > should be limited to the lifetime of the execution of a particular
> function, so
> > that shouldn't cause problems in the scenario you describe.
> I will try to prepare a minimal example to reproduce the issue. I will
> also check if it occurs with a GeoTIFF.
Yes that's definnitely something to check.
> >> Would it be hard to eliminate this behaviour (as it
> >> would make pooling Dataset objects much easier and more efficient)?
> > Difficult to tell until we have understood what really happens...
> > Do you manage to reproduce that by running under Valgrind ? If so, that
> might
> > help understanding what is going wrong.
> I never used Valgrind, but with some help, I may be able to check
> behaviour and report.
$ apt-get/yum install valgrind
$ valgrind [valgrind_options] the_binary [the_binary_options] 2>valgrind_log.txt
where the_binary will be your servlet server. Not sure how well it run within
Valgrind. You need to use a recent enough version of Valgrind to run the JVM
with it (at least for 64 bit builds). And things will run at the minimum 10x
slower
Running Java with Valgrind tends to generate a lot of warnings. You'll probably
have to check the Valgrind option that increases the maximum number of warning
messages.
> Best regards,
> Markus
> Markus Schneider
> CEO
> Occam Labs UG (haftungsbeschränkt)
> Godesberger Allee 139
> 53175 Bonn, Germany
> +49 228 93798874
> http://www.occamlabs.de
