[gdal-dev] Building HDF5 driver against the binary distribution
Joaquim Luis jluis at ualg.pt
Tue Oct 22 11:22:03 PDT 2013
Hi Ivan
I build HDF with zlib only (no szip) and dynamically but I don't
understand your question about zlib and GDAL. I don't link GDAL with zlib
Joaquim
> Hi Joaquim,
> Here it says:
> "The SZIP and ZLIB external libraries are optional for use with HDF5.
> The HDF5 pre-compiled binary distributions include the SZIP (Encoder
> Enabled) and ZLIB libraries that they are compiled with. "
> [http://www.hdfgroup.org/HDF5/release/obtain5.html]
> When they say "include" it means that the szip.dll and zlib.dll are
> there on the \HDF5\1.8.11\bin when you install the package.
> Did you compiled HDF5 1.8.11 with static szip and zlib?
> I build GDAL with the internal zlib. What about you?
> Thanks a lot,
> Ivan
> > Date: Fri, 18 Oct 2013 23:31:58 +0100
> > From: jluis at ualg.pt
> > To: even.rouault at mines-paris.org
> > CC: gdal-dev at lists.osgeo.org
> > Subject: Re: [gdal-dev] Building HDF5 driver against the binary
> distribution
> > > Hum, this reminds me very much of the very recent thread :
> > > http://lists.osgeo.org/pipermail/gdal-dev/2013-October/037257.html
> . So there
> > > might indeed be an issue with HDF5 1.8.11, and not specifically
> related to
> > > Windows. I didn't try myself.
> > > Did you try with an older Windows build provided by the HDF_Group
> ? (provided
> > > that you can download older builds...)
> > Hi,
> > I have build 1.8.11 myself and use it both in Mirone and GMT and had no
> > problems so far. It's linked as dll, not a plugin but it should not
> matter.
> > Joaquim
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131022/d8fe15eb/attachment-0001.html>
