[gdal-dev] Understanding gdal_rasterize
Paul Meems
bontepaarden at gmail.com
Wed Oct 23 01:59:51 PDT 2013
Thanks Hermann for your explaination.
I probably made a typo because now the pixels have different colors/values
as I would expect.
Thanks,
Paul
*Paul Meems *
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl
2013/10/21 Hermann Peifer <peifer at gmx.eu>
> On 2013-10-21 14:46, Paul Meems wrote:
>> I'm trying to understand how gdal_rasterize works.
>> As a test I'm trying to convert a shapefile with all counties of the USA
>> to a GeoTiff.
>> I've added a field to the shapefile called myID which is equal to the
>> shape number.
>> The goal is to create a tiff with each county its own value.
>> This is my command:
>> gdal_rasterize -a myID -l counties -of GTiff -a_nodata -999 -ts 800 800
>> counties.shp GDALRasterizeTest.tif
> You could drop "-of GTiff" as GTiff is anyway the default format.
> "-a_nodata -999" makes most sense in combination with "-init -999".
> Anything else looks fine to me.
> I'm having trouble understanding the -ts or -tr parameters.
>> Using the above command I get an 800*800 tiff which shows the USA, but
>> it looks like all pixels are the same color.
> -ts obviously sets the output file size, to 800x800 pixels, as you noted
> yourself. Do all pixels also have the same *value* ?
> Hermann
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131023/74913a42/attachment-0001.html>
