[gdal-dev] GDALColorTable - can't delete it
    Even Rouault
    even.rouault at mines-paris.org
    Wed Oct 30 08:48:27 PDT 2013
Le mercredi 30 octobre 2013 16:23:34, David Strip a écrit :
> I'm having trouble with the GDALColorTable in C++ on WIn7 using Visual
> Studio 2010
> With a function as simple as
>     void foo()
>         GDALColorTable * ct = new GDALColorTable;
>         delete ct;
> I've also tried
>     void foo()
>         GDALColorTable ct;
> and
>     void foo()
>         GDALDestroyColorTable((GDALColorTableH) ct);
> I get either unhandled exception or stack corruption errors.
> I expect there's something simple I'm missing, but it's eluding me at
> the moment.
Check that your compilation / linking flags match the ones used for the GDAL
library itself. The debug version of a GDAL build is known to use kind of
unusual flags. See what is used in nmake.opt
Otherwise a pure C solution should work :
GDALColorTableH hCT = GDALCreateColorTable ( eColorInterp );
GDALDestroyColorTable(hCT);
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
