[gdal-dev] gdal get geolocation array in HDF5 dataset
laura0 lauramail at iol.it
Thu Oct 31 01:55:25 PDT 2013
Thanks Ivan,
can you be more specific with your suggestion to use GDALWARP to transform
the Data Fields images into an output image?
Many thanks for the help,
Laura
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-get-geolocation-array-in-HDF5-dataset-tp5086505p5086790.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
