[gdal-dev] GDAL Warp API Java bindings
Kyle Shannon kyle at pobox.com
Thu Sep 5 09:19:18 PDT 2013
On Thu, Sep 5, 2013 at 10:05 AM, Markus Schneider
<schneider at occamlabs.de> wrote:
> Hi again,
> I would like to try using the Warp API from Java. It seems that there
> are currently no Java bindings available.
> - Did anbody work on Java bindings for the Warp API?
> - How hard would it be to define them? I may be able to invest some time
> here.
> Best regards,
> Markus
> Markus Schneider
> CEO
> Occam Labs UG (haftungsbeschränkt)
> Godesberger Allee 139
> 53175 Bonn, Germany
> +49 228 93798874
> http://www.occamlabs.de
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Markus,
What are you trying to do exactly?  I see that ReprojectImage() and
AutoCreateWarpedVRT are exposed in org.gdal.gdal.gdal:
http://gdal.org/java/
kss
