[gdal-dev] GDAL Warp API Java bindings
Markus Schneider schneider at occamlabs.de
Thu Sep 5 09:30:29 PDT 2013
kss,
thanks. gdal.ReprojectImage(..) looks like what I will be using then. :-)
My use case:
- My huge (ECW) dataset is in EPSG:28992
- I want to extract a defined region in EPSG:4326 as a (Java) BufferedImage
How can I get hold of a suitable destination dataset so I can use
ReprojectImage(...)?
Thanks,
Markus
Am 05.09.2013 18:19, schrieb Kyle Shannon:
> On Thu, Sep 5, 2013 at 10:05 AM, Markus Schneider
> <schneider at occamlabs.de> wrote:
>> Hi again,
>> I would like to try using the Warp API from Java. It seems that there
>> are currently no Java bindings available.
>> - Did anbody work on Java bindings for the Warp API?
>> - How hard would it be to define them? I may be able to invest some time
>> here.
>> Best regards,
>> Markus
>> Markus Schneider
>> CEO
>> Occam Labs UG (haftungsbeschränkt)
>> Godesberger Allee 139
>> 53175 Bonn, Germany
>> +49 228 93798874
>> http://www.occamlabs.de
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Markus,
> What are you trying to do exactly?  I see that ReprojectImage() and
> AutoCreateWarpedVRT are exposed in org.gdal.gdal.gdal:
> http://gdal.org/java/
> kss
Markus Schneider
CEO
53175 Bonn, Germany
+49 228 93798874
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130905/6515390b/attachment.pgp>
